building my own pc need help
ethanturner2907
46
Hi I want to build my own PC (that can run bf4 on medium settings ) and i just want to know if these parts are compatible :
-AMD fx 6300
-8gb corsair vengeance ram
-1tb wb caviar black
-gigabyte r9 270x
-Corsair carbide 400r
-750w corsair cx500
maybe you can cut down on the psu. get a 650w instead and try for 8320 or 6350
Okay thanks
1- this mobo is ok IF you are not planning on adding a second card. (one PCI-e2 X16 slot)
2- the PSU is a abit overkill, if you are not planning on adding a second card. a 520W is enough.
Okay thanks for your help
