Building My Very First PC, Lots of Beginner Questions
doubleodonut
4
Hello friends,
I am building my very first computer and am 100% a noob at it. I do not know anything but feel as though I understand things in theory after having researched a butt-ton over my parts.
My build will be (more than likely) as follows: https://pcpartpicker.com/list/CmGCNN
I'm by no means an enthusiast, nor do I plan on overclocking this machine soon. I do, however, want the capability to; in case I gain further knowledge and want to do so in the future. What I plan on doing with this PC is, for the most part, gaming. I also record and edit music, which can be intensive using the pro tools software.
CPU/ Air Cooler Questions: An air cooler is a must-have, as I do not want a liquid cooler at all. I heard coffee lake runs very hot, especially the 8700k, so I picked one of the top of the line air coolers by noctua and I want to run it in a dual fan config (hence the second fan listed and the low profile RAM).
Motherboard: I'm not completely certain on the Gigbyte mobo, I hear mixed things about all mobos. I read that people like Gigabyte for it's quality, and less about its BIOS. Given I don't know anything about BIOS or navigating them, is this a problem for a beginner? Don't even get me started on wiring and plugging in the physical cables; I'm going to have to figure that beast out slowly, while building.
Storage: I like the idea of having an M.2 drive given its ridiculous speed and load times for games. I listed a 2TB HDD for mass storage of my music files and the like, leaving my M.2 SSD for the OS, games, and other programs. My uncertainty lies with the M.2 SSD and heat; do I need additional cooling for the M.2? I read things that people say about them, and they go both ways. It pretty much comes down to "get additional cooling if you're giving the M.2 a consistent heavy load" and I'm not sure what constitutes a "heavy load" on an SSD. Games and mixing music won't be SSD-intensive, will they?
GPU: The GPU is a massive upgrade for me, and I know this is the one I want (or perhaps even a Ti if you guys think it's a good idea to have the 1080Ti over the 1080). This is also why I'm upgrading my monitor from two 1920x1080 60hz monitors to one 1920x1080 144hz and one 1920x1080 60hz. I can't seem to find a decently priced monitor with higher resolution at 144hz that is NOT curved. Gsync and FreeSync are of no consequence to me.
Case/Fans: And my case, the Cooler Master Mastercase Pro 5. I want positive air pressure going on inside for maximum cooling and minimum dust/cat hair/whatever getting inside of it. I need to have an optical drive so having 3 140mm fans on the front is a no-go, and I'm unsure how to get positive air pressure in this case without those 3 fans. Perhaps 2 140mm intake fans, the 140mm exhaust fan and one 120mm exhaust fan up on top?
Thank all and anyone who reads this wall of text to help a super beginner out. Any and all advise is appreciated and, yes, I have posted before for similar questions. I have a different build now versus when I posted my original question and think this is the build I want advise on. If there are parts that you guys think would be better for me and my build, keep in mind that my budget was $2000. With the monitor it went overboard, so nothing above what it is now preferably.
Thank you so much!
If you are going to be using this computer for ProTools, that software has some very specific requirements and lots of optimizations recommended by Avid in order to be stable. I have an older version of Pro Tools and am using an AMD based rig (not recommended), so I am not current on Intel ProTools builds. You may want to visit the DUC and look at the first sticky on this link. Start at the end and work your way back a few pages, because it is so long:
http://duc.avid.com/forumdisplay.php?f=93&order=desc
Not that there aren't very qualified builders here on Tom's, but ProTools is very unique and "picky". I use my ProTools rig soley for ProTools and nothing else. Many services disabled in startup, etc. which would make the rig not...
This would put back closer to budget.
The CPU has 6 cores just no hyperthread still fine for what your doing.
Regular SATA SSD again fine no real difference in what your doing.
Same cooler I use and one of the best made with no memory clearance issues.
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor ($279.89 @ B&H)
CPU Cooler: CRYORIG - R1 Universal 76.0 CFM CPU Cooler ($88.89 @ OutletPC)
Motherboard: Gigabyte - Z370 AORUS Gaming 5 (rev. 1.0) ATX LGA1151 Motherboard ($199.99 @ SuperBiiz)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory ($148.55 @ Newegg Marketplace)
Storage: Samsung - 850 EVO-Series 1TB 2.5" Solid State Drive ($299.00 @ Amazon)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($59.99 @ Amazon)
Video Card: Gigabyte - GeForce GTX 1080 8GB G1 Gaming Video Card ($538.99 @ SuperBiiz)
Case: Cooler Master - MasterCase Pro 5 ATX Mid Tower Case ($109.99 @ Amazon)
Power Supply: SeaSonic - FOCUS Plus Gold 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($78.99 @ SuperBiiz)
Monitor: ViewSonic - XG2701 27.0" 1920x1080 144Hz Monitor ($332.19 @ Amazon)
Total: $2136.47
Generated by PCPartPicker 2017-10-30 11:12 EDT-0400
https://pcpartpicker.com/list/3TgXjc
Bit cheaper than your original build with a higher resolution monitor and better GPU.
Also used a black and white colour scheme because Asus aura is imo the best RGB control software and the white will just reflect the colour of any leds you put in.
If you want a 1tb SSD then I'd do as above and get a 2.5" drive rather than m.2 just to keep prices down.
Not that there aren't very qualified builders here on Tom's, but ProTools is very unique and "picky". I use my ProTools rig soley for ProTools and nothing else. Many services disabled in startup, etc. which would make the rig not suitable for gaming and general use.
Latest posts
