Building New Pc for Gaming Retro nothing demanding unsure of compatibility parts etc
retroforlife
216
16
4,615
Hey i am planing on replacing a very outdated tower and wondering if any one could give me some advice :)
I've done some research and these are the parts i have found so far but not one hundred percent on compatibility etc
ps for gaming 2009 or older so not needing mega power or anything extreme :
AMD A-Series A8-7600 with AMD Radeon R7 Graphics Card
Technical Details
Brand AMD
Item Weight 45 g
Product Dimensions 10.2 x 10.2 x 2.5 cm
Item model number AD7600YBJABOX
Series A8-7600
Processor Brand Processor family
Processor Speed 3.1 GHz
Processor Socket Socket FM2+
Processor Count 4
Computer Memory Type DDR3 SDRAM
Wattage 65 watts
Gigabyte GA-F2A78M-HD2 Motherboard (Socket FM2+, A78, DDR3, S-ATA 600, M-ATX, PCI Express 3.0, HDMI, DVI-D, USB 3.0)
Technical Details
Brand Gigabyte
Item Weight 699 g
Product Dimensions 30 x 30 x 6 cm
Batteries: 1 CR2 batteries required.
Item model number GA-F2A78M-HD2
Series GA-F2A78M-HD2 (rev. 3.0)
Form Factor micro ATX
Processor Socket fm2
Processor Count 1
Memory Technology DDR3-SDRAM
Maximum Memory Supported 64 GB
Audio Details 1
Number of USB 2.0 Ports 2
Number of USB 3.0 Ports 1
Number of HDMI Ports 1
Number of Ethernet Ports 1
Number of VGA Ports 1
Number of PS-2 Ports 1
Voltage 1.5 volts
Operating System Microsoft
EVGA 100-W1-0500-K3 - 500W 80 Plus Power Supply (100-W1-0500-K3)
Technical Details
Brand EVGA
Item Weight 1.8 Kg
Product Dimensions 14 x 15 x 8.5 cm
Item model number 100W10500KR
Series 100-W1-0500-KR
Color Black
Form Factor ATX
Wattage 500 watts
HyperX FURY Series 4GB DDR3 1866MHz CL10 DIMM Memory Module - Black
Technical Details
Brand HyperX
Item Weight 50 g
Product Dimensions 33 x 11.4 x 0.3 cm
Item model number HX318C10FB/4
Series FURY Black 4GB 1866MHz DDR3
Color Black
Form Factor 240-pin DIMM
RAM Size 4096 MB
Memory Technology PC-15000, 240-pin DIMM, DDR3
Voltage 1.5 volts
CiT Venom Mesh Gaming Case with Black Interior
Technical Details
Brand CiT
Item Weight 3.9 Kg
Product Dimensions 46 x 46 x 22.8 cm
Item model number VENOM
Series VENOM
Color Black
pdf of the parts off amazon - http://www105.zippyshare.com/v/nI0SxAUg/file.html
retroforlife
216
16
4,615
Im just making a plan at the moment so not bought any thing so far just deciding what to buy etc
I would rather use HDD since i have a very large amount of older games backed up from my collection :)
Just read that the intel has less cores but i think that would be better since older games don't multi thread to make advantage of the amd apu extra cores i picked
Also any atx full sized boards you would recommend thinking of maybe making it more upgrade friendly in the future ?
