Building New Work Computer (Have old parts...Any worth re-using?)
scottamc
26
Hi All,
I currently run two computers, one at home office that acts as; gaming,work,home theater pc. This has newer parts as of a year and half ago. And then I have work pc that is just work, 5/6+ years old. I need to upgrade work PC to 3 monitor setup (two 24' dells and 1 HDTV -40-55') and need it to slice and dice regular office work and some minimal photo/video editing from time to time as well as run the two 24's and new HDTV. I will require a new SSD to run OS so that startup time and overall speed is quicker.
Looking at specs below, is any of the below salvageable to re-use (besides backup drives)? Or do I need to start from scratch? Thanks for your time!
My current work computer has;
OS-
windows 7 64 bit
CPU-
Intel Core 2 quad CPU 9450
MB-
ASUS P5Q Pro LGA 775 Intel P45 ATX Intel Motherboard
Video-
ATI Radeon HD 4850 video card
RAM-
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop
Memory Model F2-6400CL5D-4GBPQ
Hard drives-
Western Digital WD Blue WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive Bare Drive
Western Digital WD Green WD10EADS 1TB 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive Bare Drive
Seagate Barracuda 7200.9 ST3500641AS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Hard Drive Bare Drive
PSU-
ENERMAX Noisetaker II EG701AX VE(W) SFMA 600W ATX12V Ver 2.2 SLI Certified CrossFire Ready Active PFC Power Supply
also have a spare that ive never used
BFG GX Series BFGR550WGXPSU GX-550 Power Supply - ATX, Modular, 550 Watts, 140mm Silent Fan
SoundCard-
Dell Creative Labs SB0460 SoundBlaster X-Fi Xtreme Music Sound
Case-
Antec Performance One P180 Silver cold rolled steel ATX Mid Tower Computer Case
Ok, so I will upgrade the HD to a SSD. I know it's only sata 2 mobo, but I should still see huge performance increase I believe. Upgrade ram to 8gb. Should I just add 4gb (same memory I have) or get a new 2x4gb ram? Any recommendations on type? Then what video card do you recommend?
