Approximate Purchase Date: this week (the closer the better
Budget Range: $200
System Usage from Most to Least Important:Gaming
Parts Not Required: (e.g.: keyboard, mouse, monitor, speakers, OS)
Preferred Website(s) for Parts: newegg.com, or any other TomsHardware trusted website.
Overclocking: Maybe
SLI or Crossfire: Maybe
Monitor Resolution:1920x1200
Additional Comments: This is my current set up including all the parts. I'm looking for recommendations on what to upgrade from here. I've had this computer for about 3 years now, and I feel that it's starting to lag behind on some of the games. I want to prepare for games like Diablo 3, Battlefield 3 where I can play at decent settings. I'm a gamer by heart, and want performance at a good price!
So basically what I'm asking is; what components should I upgrade next to get the most performance per part replaced? What's holding me back right now? What should be bumped up to the next level? I know this is extremely open ended, and I apologize!
CASE 1 x RAIDMAX SMILODON Extreme Black ATX-612WEBP 1.0mm SECC Steel ATX Mid Tower Foldout MB Computer Case
POWER SUPPLY
1 x COOLER MASTER Silent Pro Gold Series RS800-80GAD3-US 800W ATX 12V v2.3 / EPS 12V v2.92 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
MOTHERBOARD
1 x ASUS P5E3 Deluxe/WiFi-AP LGA 775 Intel X38 ATX Intel Motherboard
GRAPHICS CARD
1 x ASUS EAH4890/HTDI/1GD5 Radeon HD 4890 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
RAM
1 x Patriot Extreme Performance 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Dual Channel Kit Desktop Memory Model PDC32G1333ELK
HARD DRIVE
1 x SAMSUNG Spinpoint F1 HD322HJ 320GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive -Bare Drive
OPTICAL DRIVE
1 x LG 22X DVD±R DVD Burner Black IDE Model GH22LP20 LightScribe Support - OEM
CPU
1 x Intel Core 2 Quad Q9550 Yorkfield 2.83GHz LGA 775 95W Quad-Core Desktop Processor BX80569Q9550
CPU FAN
1 x XIGMATEK Intel Core i7 compatible Dark Knight-S1283V REV.W with ACK-I5361 120mm Long Life Bearing CPU Cooler I7 i5 775 1155 and AMD compatible
MONITOR
1 x SCEPTRE X24WG-1080P Black 24" 2ms Widescreen LCD Monitor
OS
Windows 7 Home Premium 64 bit
So what do you guys think? What needs to be upgraded first to get the most bang for the buck out of this system? Thanks!
Budget Range: $200
Overclocking: Maybe
POWER SUPPLY
MOTHERBOARD
GRAPHICS CARD
RAM
HARD DRIVE
OPTICAL DRIVE
CPU
CPU FAN
MONITOR
OS
