Hello,
I would like to build a new PC in order to edit 4k cinema footage (on adobe). I am already equipped for the rest of the peripherals.
I know that it requires fairly expensive components but having a professional use of it (although this is not my only activity) I am ready to put a certain price. It would be good nevertheless if it could stay below 3000 euros, and if there are configs around 2000e allowing to mount 4K in good conditions, it would be ideal. If it is impossible to stay under the 3000th limit, please explain to me why and give me the minimum price to put.
I also happen to play on PC a little so it may be taken into consideration (for the graphics card for example?), but it is completely secondary (and would not in my opinion justify an increase in the budget of more than 200e).
The SSD seems to me of course mandatory and the ideal size would be 500GB in my opinion. However if that makes the budget too expensive, 250 GB will do the trick.
I know how to build my PC myself so no problem on that side. I live in France.
So much for the constraints, all the suggestions for welcome.
Thank you in advance,
Cheers
Cheers
