Building PC Help
Apple9
Hey thanks in advanced for helping. Anyway so I'm building my first computer, and I'm not all that sure what I'm doing. What I really want is advice on my first build. Mostly I'm looking for feedback on compatibility issues and if any problems with my build.
CPU.
AMD  FX-8320
shop.amd.com/us/All/ModelsPerLine/Desktop/Processor?Line=fxseries%2Ffx8-coreblackedition&Model=fxseries%2Ffx8-coreblackedition%2Ffx-8320
GPU
AMD radeon HD 7970
www.amd.com/us/products/desktop/graphics/7000/7870/Pages/radeon-7870.aspx#2
MOBO
ASUS M5A97
www.asus.com/Motherboards/M5A97/
HDD
Seagate Barracuda 500 GB
www.newegg.com/Product/Product.aspx?Item=N82E16822148767
RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233144
Haven't decided on a power supply or case yet thank you in advance.
Looks fine, pcpartpicker has a pretty solid Compatibility Filter (will tell you if something wont work) and a total power use estimation. it should help you decide on your power supply.
