Building PC help
fpmKSVK
Commendable
May 21, 2016
Hi guys,
So I need to find out if these components will work together:
CPU: Intel i5 6600k
GPU: Nvidia geforce gtx 750ti
Motherboard: gigabyte h110m-s2h
RAM: Kingston hyperx 8Gb ddr4 2133
Fan: cooler master 212x
Power supply: 400W
I hope that I didnt forget anything. And my second question is will those components work on w7? Thank you for answers.
Those parts would work together, although I would change the 6600K for a 6500 and then step up to the GTX 950. The 6600k can't be overclocked on that board and the difference between the two processors at stock speeds won't make a big difference.
