Building pc help
zavislak.jay
11
So I’m building my first pc. I’m having trouble I assume with wiring, my power supply works when I test it but when I plug into motherboard and have all cable hooked up , nothing happens when I go to turn on the pc. I have a Ab350m pro 4 motherboard. Am I not hooking the case connectors up correctly?
Are you absolutely sure that everything's hooked up? Nothing that looks like there should be a cable plugged into it?
Are there any flashing lights? Are you powering it from the case or is there any power button on the inside you can push?
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor ($199.89 @ OutletPC)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard ($74.33 @ OutletPC)
Memory: Crucial - Ballistix Sport LT 16GB (2 x 8GB) DDR4-2666 Memory ($173.49 @ Adorama)
Storage: Toshiba - P300 1TB 3.5" 7200RPM Internal Hard Drive ($39.88 @ Other World Computing)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB GAMING Video Card ($259.99 @ B&H)
Case: Corsair - Carbide SPEC-04 (Black/Gray) ATX Mid Tower Case ($39.99 @ Amazon)
Power Supply: EVGA 750g
And when I push the power button I get nothing. Dead silence , nothing running
And you're absolutely sure everything's plugged in?
