Building PC - Help!
eneko825
Hello,
I'm looking to build a pc for WoW, something that would get me covered for next expansion.
So this is what I've mustered so far, could you let me know whether the parts are not compatible to each other, or just general suggestions to make it better?
(I don't feel comfortable with the idea of building a pc myself, so I've created this list on computerplanet.co.uk, so there's not a huge variety of parts.)
Thank you very much!
Standard Fans Included With Case
Computer Case - Force Gaming Case - Green
CPU - AMD Ryzen 5 1500X (4 x 3.6 GHZ - Turbo 4 x 3.7 GHZ)
CPU Cooling - AMD Heatsink & Fan
Memory - 8GB 2133MHz (1x8GB) - Lifetime Warranty (DDR4)
Graphics Card - NVIDIA GeForce GT 1030 - 2 GB - (PCI-E) (Silent Cooling) - DVI/HDMI - HD - Supports 2 Monitors
Motherboard - Asus PRIME B350M-A (AMD B350) - 4xUSB3/2xUSB3.1
Sound Card - Motherboard Integrated HD Sound
Wired Networking - Motherboard Integrated 10/100/1000 Ethernet Lan (Broadband Ready)
Power Supply - Corsair 550W PSU - Low Noise
Hard Drive #1 - 240GB SSD SATA-III, Read 560MB/s, Write 510MB/s - Silent
Hard Drive #2 - 1TB (1000 GB) Western Digital WD10EZRX Green - SATA-III - IntelliPower - 64MB Cache - 8ms
CPU Compound - Arctic Cooling MX-4 Thermal Compound
Power Cable - 1 x 1.8 Metre UK Mains Power Cable
Wireless Networking - Wireless Network Card 300Mbps (PCI-E)
It is a fine configuration and the parts are compatible. The Graphics card performs good for WoW
http://www.tomshardware.com/reviews/nvidia-geforce-gt-1030-2gb,5110-8.html
All in all this is a strong PC, if you upgrade the graphics card later on, you will be able to play new titles as well.
The Ryzen 5 1500X comes with a cooler and thermal compound, buying the MX4 is not a must, but a clever addition. It seems to me, you know really well what you are up to!
Ryzen 5 1500X supported memory speeds:
Ryzen - DDR Maximum Frequency Support Table(For better DDR4 compatibility, it is recommended to follow the table below to install DDR4 modules. Please refer to memory support list for more details.)
Maximum DIMMA1 DIMMB1
DDR4-2667 SR -
DDR4-2667 DR -
DDR4-2667 SR SR
DDR4-2400 DR DR
SR:Single-rank DIMM, 1R x4 or 1R x8
DR Dual-rank DIMMs, 2R x4 or 2R x8
You should have no problem running memory with DDR4-2667. Enthusiasts who overclock can run memory speeds up to 3200MHz. DDR4-2133MHz is a slow speed for the processor you chose.
Kingston HX426C15FBK2/8
https://www.kingston.com/datasheets/HX426C15FBK2_8.pdf
listed as Single-rank
https://www.newegg.com/Product/Product.aspx?Item=9SIA8N25YW1388
Thanks for the feedback guys. I could squeeze the higher RAM, but the 1050 is out of budget currently. I'll stick around with the 1030 for now, and upgrade it in a year I guess. Thanks!
A GT 1030 is not a suitable graphics card, and is slower than the system recommended requirements for BfA. Ram should be in a 2x4 configuration, and at least 2666 speeds. SSD is nice, but for such a low budget system, that money is better spent on graphics and ram.
