Building PC Mobo Help!
Scotoner
31
Hello! Sorry for posting again for the same problem i have. Im gonna list what im gonna buy and feel free to give me any kind of advice if somethings needs to be changed. PC gonna be used for gaming and maybe some video streaming.
CPU: Intel Core i7 3770 3.40GHz
PSU: OCZ ZS Series 550W
RAM: Corsair Vengeance 4GB (gonna upgrade to 8gb dual channel when I can afford it)
CASE: BitFenix Shinobi
SO my problem is what mobo should I choose. I think im gonna go with z77 chipset. It needs to be under 115 Euros. Im thinking ASROCK Z77 EXTREME4-M or GIGABYTE GA-Z77-D3H RETAIL or ASUS P8Z68-V PRO/GEN3 if I actually go with the z68. Will it be much difference to go z68 vs z77.
Last question. I think im not gonna get a cooler for now so Im gonna use the intel i7 BOX cooler. Will that be ok? Also I dont think im gonna afford new case for now. I have a really old one . Will I have temp issues? Thanks!
Yes, it does support SLI, and better get case with three fans, one at front to intake cool air, one at top and back to exhaust hot air.
Nope, ''K'' at the end means it unlocked processor and you can overclock it. For your CPU you have a choice of H77, P67, B75 and H61. You can buy Z77 or Z68, but there is no point in buying motherboard for overclocking if your CPU is locked, maybe in future if you decide to buy unlocked processor. Go for P67 or H77
That's awesome. I like it. Its cheap for my budget and pretty good if you say so for overclocking and I trust ASUS.
