Hi guys,
I use my computer 12+hours a day, mostly for gaming. My budget is essentially limitless, I don't mind spending alot for quality pieces. New build should preferably be able to run VR smoothly.
I want to get into VR gaming, but the CPU requirements for the HTC Vive are more than I have atm, and my motherboard&RAM are as old as my CPU, so I will have to upgrade those aswell to be compatible with new CPU. Will also need to buy new cooling for CPU.
Have decided on the i7 8700k for CPU, looks to me like the best CPU outside the very expensive i9's, which I don't think will be necessary for me.
Rest of my system is;
GPU: Geforce GTX 1060
Harddrive: Samsung SSD 850 EVO 500GB
PSU: Not sure which brand/model, but it's 580W
Case: https://gyazo.com/8502afce160ec72d081b6549d37b30e4 - Identical to this, XPS 8100
Current CPU: Intel Core i7 860 @2.80 GHz
Current Motherboard: Dell studio XPS 8100 (not compatible with i7 8700k)
Current RAM: 8GB DDR3 (i7 8700k needs DDR4)
Looking to upgrade motherboard & RAM to something compatible and on-level with i7 8700k, and buy a cooler for the i7 8700k.
I'm also unsure if my PSU is powerful enough for the new components and I'm unsure if a new motherboard & CPU cooler will fit in my pretty small case.
If you need any more information, let me know and I will try to find it.
Any help and/or suggestions are greatly appreciated
