Building/upgrading my PC for Lightroom
thesn00ze
12
Hey guys,
I spent a lot of time travelling so I was mainly using my laptop HP Spectre 13 for photo editing but I'm taking a break from travelling and I'm thinking about building a new PC (or upgrading my current one) mainly for Lightroom. My current rig hasn't been upgraded in years and I built it almost 10 years ago.
MB: Asus P5Q Pro
CPU: Intel E8400 3GHz (clocked at 3.4)
GPU: Radeon HD7700 1GB
RAM: 8GB DDR2
HDD: Samsung SSD Evo 860, 250GB + 3TB Sata HDDs
What I'm thinking is getting just new MB (MSI Z370), CPU (i5-8400), and RAM (not sure).
I'm on a tight budget (maybe getting only 8GB mem for now). Do you have any other suggestions? Is it even worth it?
The clocks aren't directly comparable, since IPC (instructions per clock) have increased quite a bit since the Core 2 Duo debuted ten years ago. And of course, as soon as the processor does anything demanding, it instantly switches to its boost clocks, which for the i5-8400 range from 3.8 to 4.0 GHz, depending on the number of active cores. Base clocks don't really matter much. Between the improved IPC and the higher boost frequencies, an i5-8400 should be more than twice as fast even at single-threaded tasks, and much faster still at more heavily-threaded workloads...
http://cpu.userbenchmark.com/Compare/Intel-Core-i5-8400-vs-Intel-Core2-Duo-E8400/3939vs2720
I do find it kind of amusing that you are moving from an E8400 to an i5-8400 though. : D
If you don't want to spend too much on the upgrade, you could probably go with a somewhat lower-end motherboard. The main features of the Z370 chipset are overclocking and multi-GPU setups, which it seems like you probably won't be making use of anyway.
Thanks cryoburner for clarifying the difference between the two mentioned CPUs. I don't really need all the goodies from Z370 chipset, that's a good point and might save me some money.
I didn't even notice the E8400/i5-8400, that's funny.
