Hello all. I would like to request assistance from the most knowledgeable computer community online on building vs buying a new $2500 gaming/workstation PC.
In short, I am really looking at the new Alienware area 51 systems vs building my own custom system, and would very much like some expert advice/recommendations of the pros/cons of going through with either option. All expert advice is welcome, and please do give your thoughts on anything and everything you can think of as it relates to the pros/cons of each option, and what you would do in your own case. The price range and components of the system I have in mind are below, and my main use for the system will be gaming at 1440p resolution (above 1080p) playing dota 2, sc2, and other new titles to come, as well as use for a work/entertainment PC.
- Budget: ~$2300-2500
- Alienware area 51 model with x1 GTX 980 GPU / i7/ and 1TB HDD with 256 SSD
VS
- Making a custom PC ~$2500 with x1 GTX 980 GPU / i7 / and same hybrid storage setup
The primary difference I see between the two setups is: with the premade alienware, you get a really incredible looking tower with an integrated light system and good components, but you miss out on some of benefits of the new components you can get when making your own PC such as: Active PFC power supply, new USB 3.1 and type C motherboards, and a few of the newer overclocked 980 GPUs.
Please share your thoughts on what you would do given this budget and the circumstance I mentioned above, as well as any other thoughts on the pros/cons that you can think of. Thank you so much in advanced for any assistance the community can provide; its greatly appreciated.
VS
