News Building With Cooler Master’s Qube 500 Modular Case: Great Concept, Room for Improvement
Thank you for the review; however, it doesn't look like reoriented the pcie slots when you took the photo of your GPU in a mock vertical orientation. This is misleading. I believe the GPU would have fit if you had taken this step.
You used an mATX motherboard in a SFF-ish case designed to fit an full sized ATX motherboard and PSU.
The significance of this case is it's small size despite being able to fit full sized components. If you had a full-sized ATX motherboard, the PCIe sits low enough below the PSU (assuming it's mounted in the top most position in the upper right) to fully clear the PSU. Admittedly, the cables coming out the bottom of the PSU do get a little annoying.
Still, I think you misrepresented that aspect of the case. Solid review otherwise.
Reactions: Order 66
