Burned mosfet, need help!
Barteus0
Commendable
Sep 3, 2016
One of my mosfet has burned out. When i boot up my computer i get some weird screen images for a few minutes before it goes all blue. Has this something to do with the burned mosfet? And if so, is it difficult to replace?
Picture of burned the burned mosfet:
The graphics card is PowerColor HD 7950 PCS+ 3 GB
Warranty.
It's possible that the FET is impedance matched, and even if not, it's likely the symptom of a problem, not the root cause.
Not an extremely easy soldering job, either.
Your link isn't working, but I would say yes, definitely. While it would be possible to solder in a new mosfet, there no way for me to know if any other components were damaged. There tends to be a domino effect when these components fail.
