Burnt cpu power cable
Nov 13, 2018
I've been facing this issue for over a month now and I don't really know how to fix it. My power cable keeps burning no matter how many times I change it. It heats up and there's smoke coming out of it. My entire System is working well leaving that wire. There are no internal hardware problems and my Monitor is working fine too. Has anyone faced this issue before? Or if you know the solution to it, please let me know.
racksmith101
Commendable
Apr 20, 2018
656
111
If your power cable keeps burning you either have a short circuit or you are drawing far too much power through an unfused cable. Stop using your system untill you find out what's causing it because at the moment it's a fire hazard.
