G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I'm considering an 8400, and likely to go with an Outrageous Deal
or refurb. I have XP Pro media and licenses, and could save a few
bucks if I purchased a system with Home and then installed Pro. So
I'm contemplating a clean install of Pro and the potential issues.
Whatever I order will have a DVD-ROM and possibly a dual layer
DVD burner. There is some application software that goes with that...
Sonic Record Now, Power DVD, whatever. I'm wondering if there is
a way to get those installed on top of Pro. Does Dell ship those CDs
or provide them upon request? Is there some mechanism via which
specific apps can be [re]installed from the recovery partition?
Speaking of partitions, I'm trying to remember what I saw on that
4700 I played with. IIRC there was a small EISA partition, then
NTFS, then the recovery partition. A quick google suggests the
EISA partition holds the Dell diagnostics, which I suppose might be
nice to keep around. Would I have to do anything special in order
to retain the ability to run diagnostics?
Thanks in advance.
Thanks in advance.
