[SOLVED] Buying a ASRock B450M PRO4 Micro ATX AM4 Motherboard need some help
Aug 26, 2019
62
Like the question says i'm buying a ASRock B450M PRO4 Micro ATX AM4 motherboard and just need to know if this board will run a Ryzen 3 2200g out of the box don't want to have Bios problems and no way to fix them.
Also planning on buying some Ram and was just needing to know are these compatible as I can't find a list for this motherboard:
https://pcpartpicker.com/product/QRQG3C/patriot-viper-steel-8-gb-1-x-8-gb-ddr4-3200-memory-pvs48g320c6
https://pcpartpicker.com/product/XvyV3C/kingston-hyperx-fury-8-gb-1-x-8-gb-ddr4-3200-memory-hx432c18fb28
https://pcpartpicker.com/product/pTdxFT/team-t-force-vulcan-z-8-gb-1-x-8-gb-ddr4-3200-memory-tlzrd48g3200hc16c01
Thanks
Any B450 will work with the Ryzen 3 2200g out of the box. So in other words, yes the B450M pro4 will work with the 2200g.
You should not buy any of the ram kits below. Ryzen likes memory bandwidth, and a single stick is not recommended, even if it is at 3200mhz.
Here is all of of the tested compatable ram kits: https://www.asrock.com/mb/AMD/B450M Pro4/index.asp#MemoryRR
Just because the ram isn't here doesnt mean it won't work either.
https://pcpartpicker.com/product/wQmxFT/team-vulcan-8gb-2-x-4gb-ddr4-3000-memory-tlgd48g3000hc16cdc01
Something like this is compatable. I dont see this exact kit on the QVL, but i do see a simmilar one.
