Buying a Radeon GTX 1060 3GB, need to know if it will fit into my computer
Akash_37
4
it should fit, but will not run well with that weak cpu
really should put in a gtx 1050 ti MAX
to make sure open the case and measure the space for max gpu length
Ok thanks a lot, good to know. The rog strix looks good but I can only find it in 6gb. Is there a 3gb version, or would ii have to get a different one?
So if I want the 3gb version, is DUAL the best option? Sorry, I don't really understand the real differences in all of them/which would be better
There are different versions from different manufacturers.
I can't really tell which one is "better" as there are no big differences. After all, it's the same GTX 1060 3GB. Slight tweaks and improvements from different manufacturers result in these different variants. Overall, in-game performance will show only little difference, especially on PCs not so high-end.
You'll have to see the reviews for each one and then decide for yourself, also taking into account your budget. Then see which one suits you.
If you still get confused, just get the Asus DUAL one. It's good.
If you want a cheaper variant, try the EVGA one.
