Buying & building my first PC parts
Calexic
5
Hi :) I'm pretty new here. I've heard of this site before. Anyways to the point.
I'm buying a bunch of PC parts for christmas and I need to make 276% sure that everything will work fine with everything else. I don't want to spend >$700 on this to find out that either the power supply isn't enough to keep up or the processor and GPU don't like eachother
Case: Cooler Master HAF 912 Blue Edition w/ High Air Flow
Power supply: SeaSonic G Series SSR-550RM 550W
MB: GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
Processor: AMD FX-8350 Vishera 4.0GHz (4.2GHz Turbo) 125W Eight Core Processor
Graphics card: MSI Gaming N760 TF 2GD5/OC GeForce GTX 760 2GB
I can provide newegg links to the parts if you need it. Thanks 😀
for motherboard, well, actually i don't like "3" series from gigabyte..this is the lowest end from their line..
crappy bios, LLC problem and well, more rustic for overclocking..
Well, Asus M5A99FX PRO R2.0 is a much better choice at same exact price..
this one is very friendly to overclock, with a lot of options and better features that Gigabyte.
http://pcpartpicker.com/part/asus-motherboard-m5a99fxpror20
any system equipped with single gpu card will consume less than 400 watt..
let's see..
a system equipped with
CPU: Intel Core i7-3960X @ 4.3GHz
Motherboard: EVGA X79 SLI
Power Supply: Antec True Power Quattro 1200
Hard Disk: Samsung 470 (256GB)
Memory: G.Skill Ripjaws DDR3-1867 4 x 4GB (8-10-9-26)
only consume less than 340 watt as total power consumption when gaming..
and only consume 300 watt when full stressed with furmark for total power consumption..
So, your 550 gold powersupply is more than enough to run your system, and you'll still have plenty headroom
What about the CPU, GPU, and Motherboard? Will those all play nice with eachother?
That is a better motherboard from my perspective. Thanks a lot :), I didn't know about GB's overheating problem good thing I didn't walk into that trap. Thank you both for the helpful answers!
