buying from cyber power
evillord9
7
please dont try to convice not to ive made up my mind just wondering if this will run games like bf4, borderlands 2, the new assensins creed. im not excpecting ultra settings just atleast better then a console
Gaming Chasis: Raidmax Trinity Mid-Tower Gaming Case w/ USB 3.0, & Side-Panel Window (Black Color)
Extra Case Fans: Default case fans
CPU: AMD FX-4350 4.2GHz Quad-Core AM3+ CPU 4MB L2 Cache & Turbo Core Technology
CPU / Processor Cooling Fan: AMD Certified CPU Fan & Heatsink
Motherboard: * GIGABYTE 970A-DS3P AMD 970 ATX w/ Ultra Durable 4 Classic, On/Off Charge, GbLAN, 2 PCIe x16, 3 PCIe x1, 2 PCI
Freebies: GIGABYTE GC-WB867D-I 802.11AC Wi-Fi up to 867 Mbps + Bluetooth 4.0 Combo w/ Dual Antenna PCI-E Adapter
RAM / System Memory: 4GB (2GBx2) DDR3/1600MHz Dual Channel Memory (Corsair or Major Brand)
Video Card: AMD Radeon R5 230 1GB GDDR3 PCIe 3.0 x16 Video Card (Single Card)
Power Supply: 400 Watts - EVGA 400W Power Supply
Hard Drive: 500GB SATA-III 6.0Gb/s 16MB Cache 7200RPM HDD (Single Drive
Optical Drive: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
LCD Monitor: 22" Widescreen 1920x1080 Sceptre E225W-1920 LED Monitor (Single Monitor
The video card is really bad. You definitely won't get console like settings on any newer games. The only way you are going to get newer, graphically demanding games to run is if you turn all of your settings to low and turn your res down as well. It's not gonna look pretty and it's probably gonna run very badly even with the settings down. At least with the games you mentioned. Borderlands 2 might run quite a bit better, it doesn't seem to be as graphically intensive as the other games you mentioned.
Based on these stats, http://www.notebookcheck.net/AMD-Radeon-R5-M230.108655.0.html , I'm guessing you could get at least 40 fps on the BF4 Single Player if you turn your settings and resolution low enough. Now, that's playable, but it's no current gen console experience. Multiplayer.....ehhhh I wouldn't suggest it.
Whats if I go for this
AMD A8-6600K Richland Quad-Core 3.9GHz Socket FM2 100W
Rosewill Stallion Series RD450-2-DB 450W ATX V2.2 Power Supply
AMD A8-6600K Richland Quad-Core 3.9GHz Socket FM2 100W Desktop Processor - Black Edition AMD Radeon HD 8570D AD660KWOHLBOX
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin ddr3
You would sill need a dedicated graphics card in that to come close to console graphics. Maybe like a 7850 or a 750ti
i see you think you can give me a hand im looking into building a pc just went for cyber power at first just cause it was easy but would not mind taking a day off to put a pc together. my budget is 400-430 and i can only get the parts from new egg at the moment cause paypal pal bill me later. i want it asap cause the next few days i will not be working and will have time to put it together plus need to loose some wait when i game i tend to forget about food cravings so i drop weight lol
CPU - i3 4130 119.99
Mobo - ASRock H97M 74.99
RAM - G Skill Ripjaws X - 54.99
GPU - EVGA Gtx 650 1GB - 99.99
PSU - Antec VP-450 450W - 34.99 (14.99 after mail in rebate)
Case - Antec 300 - 49.99 (29.99 after mail in rebate)
All Parts are from newegg.com This should come close to console games. Maybe not on ultra settings but med-high. Unfortunately 400-430 is quite low for a budget gaming rig so I came as close as possible.
