[SOLVED] Buying Guide of the right UPS
russelbrown
35
Hi, I got a question on where do I base the right ups for a system unit? Should I base only in the watts of PSU? or should I calculate all the components of my system unit and also the monitor?
anvoice
Commendable
Jan 12, 2018
78
4
1,535
You definitely need to consider the monitor, as well as anything else you plug into the UPS. It could be that your PC draws less power than the max the PSU can supply though. Also remember that a UPS may not provide as much surge protection as a quality surge protector, if that is a concern for you.
If you do need a UPS, you would need to size it appropriately for your total Watt draw. I have a 1500VA CyberPower UPS that's rated for 1000W, for example. But I still have my main PC plugged in to a surge protector, not a UPS since I'm paranoid about that.
anvoice
Commendable
Jan 12, 2018
78
4
1,535
russelbrown
35
Oh thanks for the info. I'll keep that in mind.
