Buying new parts for buget gaming build need help ^ _ ^
TairaaTatsuya
5
are these parts stable / work perfect together? 1. Amd FX - 6300 2. Msi AM3+ 970 Mobo 3. Hyper X Savage 8gb 2133Mhz 4. Evga Nvida GTX 750Ti Sc 5. Evga 500Watt Standerd PSU 12 Volt Rail. Is this build stable or no?
http://pcpartpicker.com/p/BRX9yc
this is probably the best bang for the buck at this price point, though if you could spend 500$ you could get an R9 270X which currently MAXES out almost all games at 1080p, so your choice...
I personally believe that the 660 is better but that may be because i currently use one
The FX - 6300 Is way way more better then All The Amd A10`s
