Question Buying new pc parts.
Vilionzo
35
Hey didnt know which topic to post maybe ill get redirected, im willing to build a pc for my bro, hes willing to use it for gaming mainly like csgo gta v and games like that, budget is around 600euros, any offers?
WildCard999
Herald
Tower Only.
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor (€123.90 @ Caseking)
Motherboard: Gigabyte B450M DS3H Micro ATX AM4 Motherboard (€74.98 @ Amazon Deutschland)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory (€68.90 @ Amazon Deutschland)
Storage: Crucial MX500 500 GB M.2-2280 Solid State Drive (€66.90 @ Amazon Deutschland)
Video Card: Sapphire Radeon RX 570 4 GB PULSE Video Card (€139.90 @ Amazon Deutschland)
Case: Fractal Design Focus G Mini MicroATX Mini Tower Case (€51.46 @ Amazon Deutschland)
Power Supply: Corsair CXM 550 W 80+ Bronze Certified Semi-modular ATX Power Supply (€63.99 @ Amazon Deutschland)
Total: €590.03
Generated by PCPartPicker 2019-10-18 19:21 CEST+0200
Tower with Monitor & K/M.
CPU: AMD Ryzen 5 2400G 3.6 GHz Quad-Core Processor (€129.74 @ Amazon Deutschland)
Motherboard: MSI B450M PRO-VDH MAX Micro ATX AM4 Motherboard (€75.00 @ Amazon Deutschland)
Case: AvP Hyperion EV33 MicroATX Mini Tower Case (€28.75 @ Amazon Deutschland)
Monitor: LG 24MP59G-P 23.8" 1920x1080 75 Hz Monitor (€125.90 @ Amazon Deutschland)
Keyboard: Cooler Master Devastator 3 Wired Gaming Keyboard With Optical Mouse (€32.83 @ Amazon Deutschland)
Total: €592.01
Generated by PCPartPicker 2019-10-18 19:24 CEST+0200
The monitor is Freesync so it will work smoothly with the Vega 11 iGPU although you may want to run most games in 720P on Low settings to keep the FPS at a playable rate as the Vega 11 iGPU performs close to the GT 1030.
Reactions: RodroX
As @WildCard999 mentioned, it's important to know if there's already a monitor, keyboard, mouse, and OS license already existing. Those costs do add up.
Also, in the effort to keep costs down, would 720p be acceptable? I've sort of been toying with the idea of a complete build, including screen, by using a new 32-inch or so 720p TV, and an RX 570 video card, though, while that's doable in US prices, I'm not sure whether it's equally economical in Europe.
RodroX
Upstanding
Aug 4, 2019
345
100
390
Heres one option (https://es.pcpartpicker.com/list/6wN7hg):
Type|Item|Price
CPU | AMD Ryzen 5 2600 3.4 GHz 6-Core Processor | €134.08 @ Amazon Espana
Motherboard | ASRock B450 Pro4 ATX AM4 Motherboard | €91.41 @ Amazon Espana
Memory | G.Skill Flare X 16 GB (2 x 8 GB) DDR4-3200 Memory | €84.13 @ Amazon Espana
Storage | Western Digital Blue 500 GB 2.5" Solid State Drive | €64.98 @ Amazon Espana
Video Card | Asus Radeon RX 580 4 GB Dual Video Card | €138.85 @ PC Componentes
Case | Fractal Design Focus G ATX Mid Tower Case | €60.82 @ Alternate
Power Supply | Corsair CXM 550 W 80+ Bronze Certified Semi-modular ATX Power Supply | €72.90 @ Amazon Espana
| Prices include shipping, taxes, rebates, and discounts |
| Total | €647.17
| Generated by PCPartPicker 2019-10-18 20:11 CEST+0200 |
You can start from here and then update along the road, you could go with a Ryzen 3000 or 4000 next years, or swap the GPU, etc, etc, etc. Also you can drop the SSD (or change it for cheaper brands) and just go with an old fashion 1TB HDD.
Also, as other mention already, you never said if you need a monitor too!
Vilionzo
35
Updating - monitor should be not included it will be bought seperetly from prince range, and thinks like keyboard mouse etc is out of question also, only a pc. Want to squeeze like the best optimal pc from that prize.
Vilionzo
35
And what about mobos you all offerimg b450, im not really and expert but i heard some mobo requires flashing with an old ryzen cpu if im right on this one?
boju
Champion
4xx series motherboards support Ryzen 2000 out of the box. Ryzen 3000 series CPUs may need a bios update depending how old the stock is. Newer 4xx boards should be updated with a Ryzen 3000 ready sticker on the box.
Msi is the only brand i know of for Amd that have an update bios feature performed without a CPU.
RodroX
Upstanding
Aug 4, 2019
345
100
390
As boju said, all motherboards with B450 or X470 chipsets should be able to handle Ryzen 2xxx cpus out of the box. Later on if you plan to upgrade to Ryzen 3xxx or 4xxx you will need a BIOS update which you can perform using your old Ryzen 2xxx.
