Question Buzzing noise coming from the headset, rear audio
gabizinha
37
Hi everyone.
I just built my very new PC:
B450-F Strix,
Ryzen 3600x (with hyper 212 cooler),
GTX 1070 EVGA,
16GB ram,
CM Masterwatt 750w PSU.
However, when I plugged my Hyperx Cloud Core in the rear audio output of my motherboard, I began to hear a buzzing sound.
I tried everything:
Uninstalled/installed drivers;
Disabled/enabled audio device;
Installed old realtek drivers;
Used generic windows driver and etc.
None of that seems to work.
I'm starting to lose my mind because it's a very annoying sound!!
What I can possible do? 😕
You should first make sure you're on the latest BIOS update for your motherboard. Then you should make sure you're on the latest drivers for your platform. You forgot to mention the make and model of the PSU, please include that.
Have you made sure that the same doesn't happen when plugged to the front panel audio connectors? Speaking of connectors, are you using the splitter for the headset or are you plugging it directly without a splitter? I'd also ask you to pass on the make and model of the case.
I believe my BIOS isn't the newest one.
The drivers are the latest and up to date.
My PSU is the masterwatt 750w from coolermaster.
I'm not using a splitter, its directly to the motherboard
Hi everyone.
B450-F Strix,
GTX 1070 EVGA,
16GB ram,
I tried everything:
2 main reasons
1.grounding issue
2.capacitor loosing capacitance but it doesn't effect your sound quality
