I attempted to record the sound in this video:
GIGABYTE GTX 1660 Ti Mini ITX OC - coil whine / strange sound? - YouTube
Edit: video of a different GPU making a very similar noise: weird GPU noise - YouTube
After running for a few minutes playing a demanding game (in this case, playing RDR2, but it happened with Death Stranding as well), the GPU will start making this sound. Most audible between 0:01 and 0:04, as well as 0:17, despite the cooler above running at 100%.
There are no performance issues whatsoever; the game was running at 60 FPS. I've only ever seen a black artifact once while watching Netflix.
Is it just a dust issue, or it could be something else entirely? Perhaps the PSU, which I've been told is horrible?
Edit: it also doesn't appear to be related to fan speeds, as I've tried changing them with MSI Afterburner to no avail. The GPU has to be under load for the sound to occur.
System Configuration:
- Operating System: Windows 11 (clean installation)
- CPU: AMD Ryzen 5 3600, no overclock, PBO set to Auto
- CPU Cooler: Arctic Freezer 34 eSports Duo
- GPU: GIGABYTE GTX 1660 Ti Mini ITX OC
- Motherboard: MSI B450 GAMING PLUS MAX with E7B86AMS.H50 (11/07/2019) BIOS
- RAM: Corsair Vengeance LPX DDR4 3000 MHz (2x8), XMP enabled
- PSU: Corsair VS650 (2018) 650 W
- Monitor: BenQ GL2450
- Case: Thermaltake V200 Tempered Glass (modded for proper airflow - front panel removed, mesh filter installed)
- Fans:
- Front intake: 3x120mm Arctic P12 PWM PST CO
- Rear exhaust: 1x120mm Thermaltake stock
- Power plan: Ryzen Balanced
