Buzzing sound from Diamond Pro 930SB
BlackDawn
Hello everyone.
I've bought a DP930SB (white/silver cabinet)
and while i am very happy with the picture quality
which is much better then my old Mag 786FD
I'm able to hear a low buzzing sound from my monitor
which is slowly but surly driving me nuts
is this normal? or do i have a faulty unit?
i every electrical device (other then my comp) in my room is turned off so there is nothing to cause
an electrical disturbance.
any ideas?
thank you.
BD.
yeah my monitor does it too, i totally know how you feel.
however unfortunatly the sound is not in the specs set out by the company so there is little you can do about it.
Alltaken
<A HREF="http://www.mud-puddle.co.nz" target="_new">http://www.mud-puddle.co.nz</A> its where its all going on
Monitors should not make noises no matter how faint they are. Contact their support, or if you still can take it back to where you got it and replace it.
