Question Buzzing Sound
simmyx
345
15
4,695
PC makes a slight buzzing sound. If I lift the case up it goes quieter. I thought it was the HDD so I put a rubber band around the HDD tray to absorb the vibrations and now it's much quieter.
Earlier my PC went unusually quiet, I then opened up an app and heard the buzzing sound which starts when I first turn my PC on.
Would this indicate the PSU ?
It was the sound I heard when everything boots up after I turn my PC on.
PSU is a RM750x
Thx
simmyx
345
15
4,695
I doubt the RM750x isto blame but let's get your full system specs.
Also let us know exactly what you are running to generate the 'noise'.
-- Ryzen 5 3600 --
Corsair Vengeance 32GB 3600mhz RAM --
3060Ti FE --
RM750X PSU --
Kraken Water Cooling --
-- B450 Max Mobo --
5 x Corsair RGB fans --
Meshify C Case
128GB SSD
1TB HDD
