I have a question about Core 2 Duo temperatures. I have thoroughly read (and understand about ninety percent of) the stickied guide on the subject, before anyone suggests I start there.
I just successfully built my first from-scratch PC, and am interested in overclocking the processor a bit, but the temperature readings I am getting from various sources are confusing, and I want to make sure I'm not cooking my system before I do anything stupid.
I'm using a:
Gigabyte GA-965P-DS3 rev 1.3
Core 2 Duo E4300
2 X 1 G.Skill 6400 RAM
I'm using the stock CPU cooler and my case is an Antec 180b with all three fans running on high. The readings I am about to give are for a system that is not currently overclocked in anyway.
So anyway, when I run TAT, both cores idle around 50c, full load around 70c, which according to the stickied guide is pretty high, especially considering the fact that nothing has been tweaked.
However, when I run Core Temp and SpeedFan, they have almost identical readings that are a good 15c - 20c below what TAT is showing: both cores idle around 31c, full load (with TAT) around 57c. Also, the temperature in SpeedFan that corresponds to the Tcase idles around 22c, a few degrees higher than the temperature my BIOS displays on startup, which seems to fit.
What gives? Do I trust TAT, which suggests that, for whatever reason, I am already pushing it temperature-wise? Or do I trust Core Temp and SpeedFan, which both suggest that I've got plenty of room, at least in terms of temperature, to overclock my CPU?
One last thing that is probably important: after first seeing even higher temperatures in TAT, I opened up my box and discovered my CPU cooler was visibly loose. I reseated it, and my temperatures dipped accordingly. I assume for this reason that any problems I am having don't have to do with re-seating my cooler.
Thanks a ton, and in advance, to anybody who responds to this.
I'm using a:
Core 2 Duo E4300
