Cabinet Fan Made no difference in temps
rawfiul
88
so i have 5 case fans running on max rpm and if i power them all off, i see no CPU/GPU temperature rise.
3 intake, 2 exhaust properly positioned
i was just testing how much case fans actually help with temps and results were no diff at all.
i just wana know am i the only one?
i5 8400
zotac 1060 6gb
fans are local but not cheap
There may not be much difference in a big case....or if your load isn't huge.
Perhaps you have so much of the case open that air flows pretty good anyway.
Maybe if you let it sit for a while you will see more of a rise.
yes i felt this too
that fans might help in stabalizing temps if not reduce
