Solution aevm Jan 26, 2014 I'd make them blow the hot air out - hot air rises anyway so you might as well take advantage of that instead of fighting it.
aevm Illustrious May 18, 2007 11,974 0 41,960 Jan 26, 2014 Solution #2 I'd make them blow the hot air out - hot air rises anyway so you might as well take advantage of that instead of fighting it. Upvote 0 Downvote Solution
enjoiskaterguy Distinguished Dec 21, 2013 104 0 18,690 Jan 26, 2014 #3 Definitely OUT. Heat rises and you want your fans on top to blow that hot rising air out...not keep it in. Make sure to check the direction of airflow of the fans before installation. Peace! Upvote 0 Downvote
J Jacob James Honorable Dec 10, 2013 43 0 10,530 Jan 27, 2014 #4 aevm : I'd make them blow the hot air out - hot air rises anyway so you might as well take advantage of that instead of fighting it. Thank you for your response Upvote 0 Downvote
J Jacob James Honorable Dec 10, 2013 43 0 10,530 Jan 27, 2014 #5 enjoiskaterguy : Definitely OUT. Heat rises and you want your fans on top to blow that hot rising air out...not keep it in. Make sure to check the direction of airflow of the fans before installation. Peace! Thank you very much for your valuable response. Upvote 0 Downvote
