Cabinet problem
harishphk
63
hi guys i am going to upgrade gpu to hd7770 and i am confused whether the gpu is large in size and
whether it will fit into my cabinet or not
cabinet : http://www.zebronics.com/products/cabinet-reduced-height/king
gpu : http://www.sethiainfotech.com/msi-radeon-hd-7770-ghz-edition-1gb-gddr5-pci-e-graphic-card-r7770-2pmd1gd5-oc.html
and i also want to know whether this gpu fits my motherboard also
mobo: intel dh61ww
how much power supply does this gpu requires and does it requires any pci-e connector
thank you in advance...
aroud here it's called a "case" not a "cabinet". yes it will fit, unless you do something strange inside your case or get an unnecessarily long card. Look at the inside and measure. It takes one connector and 80-90w.
edit: the linked card is on the long side, look for an 8.5 if you're worried.
abbadon_34
harishphk
63
is buying the above gpu is on safe side or not for this case. because this is the lowest price for that gpu
