Cabinet + PSU for i7 & 5970
itisravi
89
Please suggest a good Cabinet + Power supply for this build
i7 860
Ati 5970
2 RAM modules
2 HDDs
Overclocking will be moderate at max and another 5970 is out of question. Budget for Cabinet+PSU = $200-220.
(Please suggest a cabinet from Antec/CoolerMater/Thermaltake as these brands are easily available in my country)
CM HAF 922 (Most probably would have enough space for that graphic card. (The case is 22" Long so most probably that 13.5" graphic card would fit...but most probably would interfere with the HDD cage...
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
PSU - Corsair 550VX/ Corsair 650TX/ Antec EA 650/ ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341023
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371015
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371021
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341018
The 550W would be little close...So stick with 600W + PSUs...
Total - ~$200
Similar threads
