hello mentor i pleased to say i buy new cabinet but if you help me to decide which cabinet good for mine i chose crosair 400r carbide or cm690 2 advanced or nzxt guardian 921 rb which one is best my budget is 100 $ only
Depends on what you want to do with your system in the future etc. and it also depends on how you want it to look, if you're concerned with cooling or expanding in the future etc.
But, since you are on a budget, you can buy a perfectly functional case for half that amount.
For example, the Antec 300 illusion model. $55 after rebate, with free shipping.
Watch out for case shipping costs, cases are heavy and expensive to ship http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
The case, in my opinion, should never take up more than 10% of your total budget. It's just unnecessary unless you really have some burning desire for a specific one
