Question Cable directions matter?
RenTheReaper
Great
Mar 29, 2022
170
As long as the cables go with their respective pins, does it really matter which direction (if we take where the labeled side is "upward") smaller case cables like positive/negative Power LED, or Power Switch face?
Ralston18
More information please.
What are you connecting?
If polarity ("direction") matters then most systems and products use connectors to ensure that only the correct polarity is is physically possible.
Do not plug in anything.
What are you dealing with?
Reactions: KyaraM
RenTheReaper
Great
Mar 29, 2022
170
I'm just missing the Power Switch cable now but I'm not sure if I should connect it in a certain way (out of curiosity, does GND mean ground and if so, do I connect any negative ends of a two pin cable there?)
boju
Ambassador
Power and reset doesn't matter as all the button does is bridge the two pins to do it's function, like using a screw driver to short the pins but with button instead.
Other led lit functions youd follow the diagram connecting pins to the correct sides of the wire. It doesn't matter if print is top or under for bridging connectors albeit if corresponding pins orientate the connector and print a certain way for other pins following a polarity +/- then orientate print the same way for everything else for consistency.
Reactions: CountMike
