Cable Help Needed.. Connecting PSU to GPU
dj nance
30
My GPU (GeForce8800gtx) has two 6 pin pci-e power inputs.
My Psu (corsair hx520w) has two 6 pin pci-e power outputs.
Why can't I find a cord that will connect the two? Can anyone please help? It needs to be at least 12 inches long (preferabbly a little longer).
My other option is to go with the pci-e conversion to dual 4 pin connectors, but I don't understand why I can't seem to find any pci-e to pci-e cords.. do they not make these?
Thanks
Are you saying that your power supply is a modular one and you can't find the pci cable that was supposed to come with the power supply. Either I am reading your post wrong or something but you said that the card has two 6 pin inputs and your power supply has two 6 pin outputs what is the problem then.
If the cables are there and they are too short then you need exstensions ?
*** NEW *** Kingwin 6 pin PCI-Express Extension Cable - 12" $3.99
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=34_186&products_id=30525
You need two of these this particular one is 12" and they do have longer.
BitFenix 6-pin Video Card Extension Cable - 45 cm - Black Sleeve 17.7" $7.99
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=34_804_1011&products_id=31725
dj nance
30
Thanks for the help.. I'm afraid I have found the real problem now.. I just discovered that my gpu has an 8 pin pci-e connector (the aforementioned 6 pins are inputs I guess?).
Here we go again!
If your PSU has two 6 pin PCI power connectors and your video card needs one 6 and one 8 pin connector, just use both 6 pin PSU connectors. If you look really close at an 8 pin (or 6+2) PCI connector, you will see that the two extra wires are ground lines.
Assuming the same wire gauge, an 8 pin connector cannot carry more power over its 3 hot wires (the yellow ones) than the 6 pin connector can carry over its three hot wires.
