Question Cable layout for a Cool Master Storm Trooper case
amerifax
206
Cable layout for a Cool Master Storm Trooper case ( Case purchased in 2013)
System
AMD Ryzen 9 5950X
Asus ProArt X570 Creator WI-FI
Upper panel cables are the issue. Cool Master was no help. I should have saved the diagrams for the case. Oh well, live and learn.
4 Pin Male - Looks like some kind of power Connect. (No place for it on the motherboard).
3 Brown & Black Cables. Might be lights or fans.
1 White & Black
1 Black with a "Y" type connector (Same connecter as White & Black.
I don't see anything on the motherboard that would accept the connectors.
Bob
Ralston18
Also very possible, for example, that some other connector or adapter is missing from the cables that you have.
Do you have a specific case model number, part number, or some other identifier unique to the case?
Any other numbers or information on the case?
I made a couple of attempts to find an applicable case User Guide/Manual but a couple of the sites turned out to be fake Microsoft warnings/traps forcing me exit as quickly as I could find and do.
Not at all uncommon ....
Willing to try again if there are other details that will help filter and focus the search criteria.
In the interim, take some photographs of the cables and case.
Post the photographs here via imgur (www.imgur.com).
Someone may recognize the cables and components and be able to help directly or identify potential sources for the necessary connection instructions.
Many products are generic and thus identical other than the branding (name). Recognizing a generic product may result in a direct answer or otherwise lead to such an answer.
Still, even after 9 years, there should be some useful bits out there.
amerifax
206
System
AMD Ryzen 9 5950X
1 White & Black
Bob
The Case - Storm Trooper
Model - SGC-5000-KKN1
Purchased - 089/30/2012 ( Shure wish I could replace the Front Panel).
Cables - See included Picture of connectors (To Follow)
Post the photographs here via imgur (www.imgur.com). Found site a-OK. But not sure what to do.
amerifax
206
I have added the image see message below.
Bob
Ralston18
Still not working.
"To protect your security, imgur.com will not allow Firefox to display the page if another site has embedded it. To see this page, you need to open it in a new window."
Opening in a new window made no difference.
Go directly to www.imgur.com
Click the green "New Post" button in the upper right.
Drop the images in the indicated area.
Then copy the resulting URL provided and post herein.
amerifax
206
Still not working.
In the above image, I was able to select View: https://amerifax.imgur.com/all/ and see my image. Now, I'm more interested in having the ability to show the image that's located at www.imgur.com.
