Cable Management Holes Ruber Gromets for Cooler Master HAF 932
ccoo84
434
5
18,815
Hi I'm looking for some rubber Gromets to fit into n the cable management holes on the HAF 932 Advance.
I can't seem to find them anywhere, does anyone know some that will fit? Maybe from a different case or something I'm in dire need to complete my custome build, I would hat to have to buy a new case just because of some rubber Gromets.
Thank you
So there are no cables going through the hole and you want to blank it off.
What you require are blanking grommets.
You will need to measure the hole and search for the correct size.
If there are cables to go through the hole then all you need to do is fit the blanking grommet then cut across it with a sharp knife.
