Hi all,
I just completed my first PC build about 10 days ago. Everything works great so far, so I'm absolutely thrilled, but I had a few questions about the cables.
1.) I did order some velcro ties for cable management, but when I was building, I just used the twist ties that came with my case/monitor (i.e. not like the cheap twist ties from the grocery store). I only ended up needing two to keep things organized decently well, and now that it's all built, I don't particularly want to open it up again and potentially jostle anything out of place. Do you think the twist ties are okay, or would it be better to put in the velcro ones or some zip ties?
2.) I ended up putting most of my cables (particularly the ones for my optical drive/SSD/HDD) behind my motherboard. As a result, it's a bit crowded back there, and it was a little tight putting my case's back end on, but it closed without too much trouble. Is that okay to leave as it is? The cables seem pretty durable, but if it's not good to have them like that, I could try to find space somewhere else (though again, I'd rather not open up the case if I don't need to. I'm a little paranoid about breaking something after putting so much hard work and love into this machine, haha
Thanks again for all the help!
