Cable Management & SSD placement
Jan 1, 2014
So, here is the picture of my case (Cooler Master N200) and cable management, and as you can see I've done just about as much as possible. Now, there is a hard drive cage that is detachable, and as I have only a single hard drive there is no need to have it in. I was thinking about adding in an SSD, and was not quite sure where to put it. There is a spot directly beneath the 3.5" bay where an SSD can be mounted, along with two spots on the back panel, however those are inaccessible due to cables. The spot under the hard drive doesn't look secure. What is my best course of action, in where to mount the HDD and SSD?
http://imageshack.com/a/img22/3831/d423.jpg
If you really wanted, you could just hook up an SSD's cables and just peg it at the system and close the side panel. They don't vibrate or have any moving parts, whether it has a secure mount or not doesn't really matter.
I would get some double sided adhesive tape, and stick it to the underside of the 5.25" bays.
