Cable Mod PSU cables.
PatoGD
21
They are extensions and are compatible with your PSU (actually, all ATX PSU's) since they simply extend the length of the cables you are using.
Get them, use them and enjoy the look
So no matter what PSU I have,(as long as its ATX) I will be able to use them without worriying about my pc blowing up?
Well, they aren't magic, if you have a very lousy PSU, they won't make it any safer but, yes they'll work on all ATX PSU's. And do take into account what Zerk2012 says, those extensions are quite long and may be difficult when it comes to cable management. I imagine shorter ones would likely be easier to work with.
PS, I accidentally unselected the solution... oops
Eh, since I can't find any other black and white sleeved cables, could you link some that are comaptible with my PSU :)? I found some Corsair ones but they're really expensive and 24 pin cable isn't even included...
