cable modem problem with win2k
sparks219
152
I'm running win2k professional and my cable modem connction seems to ah heck up quite a bit. When I run photoshop, dreamweaver, winamp, icq, my internet connection seems to stop working. I check it by typing ipconfig under MS DOS prompt, and it tells me that application failed to initialize properly. I can try different applications, and I get the same error a lot. This is a really annoying problem, does anyone know how to fix it?
I'm running windows 2000 pro with SR1, P3-800E on an Asus P3B-F, and 256MBs of ram.
Thanks
Sparks
crapple0
158
if it's an external cable modem, connected to your NIC (Network Interface card), try updating the NIC's drivers. I suspect something causes your cable modem to decide your computer is off and ditch its assigned IP.
~Crapple0
"the greatest trick the devil ever pulled was convincing the world he didn't exist"
sparks219
152
Thanks for the reply
I looked at Dlink's website for newere drivers. Unforunately, they don't have any windows 2000 drivers for their DFE530TX cards :'(
Could it also be sometihng else? I know the NIC is good because it works like a dream under FreeBSD.
Thanks
Sparks
crapple0
158
go to best buy and get a $20 NIC. If the problem doesn't go away, return it.
Another note...have you tried talking to your cable provider? it might be a faulty modem or something
~Crapple0
sparks219
152
I called up my cable modem provider and the moron told me I don't have enough ram duh!!
I talked to my friend and he used to have the same problem. He told me it was the buffer settings in windows 2000.
I'll try another NIC I have lying around and see what happens. A 10mbps NIC should be sufficient to handle my internet and file transfer ..etc :)
Sparks
G
Guest
Guest
Im running an AMD700 with 256 MB of ram and i have no problems running win2k with a cable modem...
You have plenty of ram
sparks219
152
eemm.. I talked to my friend and he said it's a buffer underrun problem. He mentioned that windows 2k has a small desktop buffer or something...and I changed the buffer settings with TweakI, and the problem is still there. I'm going to try another NIC tomorrow and see how that goes
Sparks ;)
G
Guest
Guest
I believe you’ll find that Photoshop is the culprit. I have seen the same thing on other workstation’s running Photoshop 5.5 under W2K SP1. This only happens after Photoshop has been open for a while. I was looking for a workaround myself but for now I have them disabling their NIC’s while Photoshop is open and enabling them breifly when checking mail or if they need network access. A little hassle but simple to do and better than rebooting for now.
