Cable sleeving a Corsair CX750M
Hayden Ross
112
I'm wanting to cable sleeve my psu (Corsair CX750M) cables. But, i have ran into a problem the psu it's modular besides the 24pin connector. However all the other cables are like ribbon cable. How would you go about sleeving the wires individually ? would you just push something like a ball point pin in between the wires so that they separate without cutting insulation then slowly pulling them apart or what? Also if you guys could send me a link to a good cable sleeving kit that includes the tool to push the pins out of the connector , etc. If its not possible its fine ill just order some cables that i like. Just like doing things myself. Thank you for your time and answers.
Are you still looking for info about your cables?
yes i still am
+1
Cable sleeving is really expensive. If you MUST have it, buy a corsair AX series or something worth sleeving, then spend another 100$ on the sleeved cables.
It would really be difficult to sleeve it yourself with any form of neatness.
