Cables help
mrwil
132
i just got this 2day http://www.newegg.com/Product/Product.aspx?Item=N82E16820148442
i'm using my hd cables on it but now i need new cables for my hd 1tb
or to switch it back to my hd is this 2 cable all i need? are there long enuff for my case
http://www.newegg.com/Product/Product.aspx?Item=N82E16812123188
http://www.newegg.com/Product/Product.aspx?Item=N82E16812201002
computer spec i5 2500k oc 4.5
asrock extreme 4 gen 3
corsair vengeance 8gb ram 4x2
evo 212
7850 asus
power 650w http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
Case http://www.newegg.com/Product/Product.aspx?Item=N82E16811156252&Tpk=Raidmax%20Aeolus
also is this normal for my ssd?
Hello,
Your SSD is set to IDE mode in your BIOS, you need AHCI to get the maximum performace out of your SSD.
Notice in AS SSD on the top left it says "PCIIDE BAD".
Follow these instructions to change your computer to AHCI:
To resolve this issue, enable the AHCI driver in the registry before you change the SATA mode of the boot drive. To do this, follow these steps:
1.Exit all Windows-based programs.
2.Click Start, type regedit in the Start Search box, and then press ENTER.
3.If you receive the User Account Control dialog box, click Continue.
4.Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINESystemCurrentControlSetServicesMsahci
5.In the right pane, right-click Start in the Name column, and then...
Hello,
5.In the right pane, right-click Start in the Name column, and then click Modify.
6.In the Value data box, type 0, and then click OK.
7.On the File menu, click Exit to close Registry Editor.
This was found here: http://www.ithinkdiff.com/how-to-enable-ahci-in-windows-7-rc-after-installation/
There is also a regedit file you can use on that website that will do exactly that.
Do this and try out your benchmark again and re post it and see what it shows.
What exactly did you do? Did you read the whole article thing first?
Did you do the software switch before changing to AHCI in the BIOS? If not, change it back to IDE, reboot and do the software switch first.
yea i read the article did the registry guide and restarted my pc went to bios went to advance tap and enable ahci saved it restarted pc and bsod just came up. i will post a video in a few when YouTube finish uploading .
