Hi,
I am looking to build a computer for use with theses applications-
Autodesk alias,
Autodesk 3ds max
Solidworks
Keyshot
Maxwell
Maya
Adobe after effect
Adobe phtotoshop
Adobe primier pro
Google Sketchup
I would much appreciate any opinions, suggestions and advice on this build to make sure i have got everything right!
This is the build-
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor
CPU Cooler: Noctua NH-D14 65.0 CFM CPU Cooler
Motherboard: Asus Z87-PRO ATX LGA1150 Motherboard
Memory: Patriot Viper 3 16GB (2 x 8GB) DDR3-1866 Memory
Storage: Samsung 840 EVO 120GB 2.5" Solid State Disk
Video Card: Sapphire Technology AMD FirePro W5000 2GB GDDR5 DVI DP PCI-E Professional 3D Graphics Card
Case: Fractal Design Arc Midi R2 (Black) ATX Mid Tower Case
Power Supply: Corsair RM 750W 80+ Gold Certified Fully-Modular ATX Power Supply
Monitor: Dell U2414H
Operating system: Windows 8 Pro
I am going to add a extra hard drive at a later date. I also was wondering if there is any point in me getting and xeon processor instead of the i7 for my type of work in the same price range such as the e5 1620? And i was also wondering how much benefit i will get from the 1866 ram over normal 1600 ram, is it worth the extra cost?
Many thanks
Autodesk alias,
Autodesk 3ds max
Solidworks
Keyshot
Maxwell
Maya
Adobe after effect
Adobe phtotoshop
Adobe primier pro
Google Sketchup
This is the build-
Many thanks
