Hi All,
I know there is someone much more knowledgeable than me out there that might even be willing to pass some knowledge onto me.
I am looking to build a pc capable of running CAD applications namely Creo 2 (elements pro) and solidworks. It will also need to run PS and matlab and all the standard day to day stuff.
So I was planning on getting my hands on a nvidia quadro possibly going to try and pick up a second hand one a bit cheaper as it will only be a cad pc for a year and then i plan on getting a gaming card.
I have made a mock up of the system (video card not included)
CPU: Intel Core i7-4790 3.6GHz Quad-Core Processor (£219.54 @ Aria PC)
Motherboard: MSI Z87-G41 PC Mate ATX LGA1150 Motherboard (£48.31 @ CCL Computers)
Memory: Kingston 16GB (2 x 8GB) DDR3-1333 Memory (£99.97 @ Amazon UK)
Storage: Crucial MX100 256GB 2.5" Solid State Drive (£74.39 @ Aria PC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£35.94 @ Aria PC)
Case: Xigmatek Recon ATX Mid Tower Case (£30.55 @ Amazon UK)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply (£59.05 @ Amazon UK)
Total: £567.75
Generated by PCPartPicker 2014-10-02 21:45 BST+0100
My total budget would ideally not exceed £800 but can be stretched to £1000 if it will harder/better/faster/stronger/longer!
Thanks in advance for any advice
Total: £567.75
I going crazy trying to make this descission and I need to get is sorted by last week to start work on my project!!!
