I'm trying to understand something about PSU efficiency using this copy/pasted definition of the 80 Plus certification...
"The 80 Plus certification tests the efficiency of a PSU at different loads. The loads are 20%, 50%, and 100% of the maximum power output. A PSU that is 80 Plus certified must have an efficiency of at least 80% at 20% load, 80% at 50% load, and 80% at 100% load."
So if I have a 470 Watt 80 Plus Bronze PSU that is pulling 235 W at the power point (i.e. operating at 50% load and therefore at 85% efficiency at the Bronze level) - is it saying that approximately 15% of that 235W is lost to heat and the actual load at the PSU output would be closer to 200W?
For context - I'm deconstructing a HP Z400 down to PSU, CPU, RAM, HDD and reduced power consumption is a side priority for that. I'm currently down to 165 W but I'm hoping to get down closer to 100 W and that would put me in the lowest efficiency bracket for the standard 470W power supply its currently fitted with so I need to consider that.
Thanks,
Thanks,
