Call of Duty 4 Low FPS
G
Guest
Guest
Ey Guys I need Help My Fps Is Really Low 59-71 so can some one help me pls ? xD i mean Is there Any Bind's Or somthing to help me O_O
jwk3
423
what are your system specs? and also, 59-71 FPS is perfectly fine. check that you haven't turned on Vsync. From the top of my head cod4 doesn't have a default FPS limit.
it actually does. its set at 91 out the box. but you can change it by turning the console on and changing the maxfps cvar.
listing your hardware will help us diagnose your issues. but you will get the best performance by setting everything other than textures down to minimum/low...
Blahman11
205
59-71 isn't really low, quite the opposite in fact. Cod 4 on the consoles rendered at 30 fps. I used to play it on my laptop in the high 20s and still got played ok. I wouldn't worry really
