Call of Duty: Advanced Warfare Black Screen Problem
drjackool
285
Hello
I install BlackBox version of above game. After game load and select mission when enter game scence the entire screen is BLACK but game sounds is hearing and text and subtitles are shown. I changes graphic settings to solve this problem but not work any things i made.
I update my VGA driver to latest but not work.
My system spec:
CPU: i5-3570K
RAM: 8GB-2133MHz
MAIN: GA-Z77-D3H
VGA: Intel HD Graphics 4000 (Integrated on CPU)
OS: WIN8.1
DVMT: Max
Graphic Mem: 1024 (shared about ~1700 MB)
By this system I played following games correctly and perfect:
COD: Ghosts, Deadspace3, Crysis3, NFS: Rivals,...
Please Help Me...
Some times the game load correctly but '1 in 1000'
your intergrated gpu isnt up to spec mate for anything more than low medium, its also not offically supported hardware so updating the gpu driver will likely not help.
your best bet is get a cheap ($100+) gpu and you will be able to play any game you like.
What is your choose for $100 GPU? can I buy a GTX series?
Always always alway got a 'can I run it' questions, then GO TO
WWW.CANIRUNIT.COM and look for yourself. The RECOMMENDED hardware is what will make the game 'like I saw on youtube'. If you don't have it then NO it won't play like you saw on youtube. You can either PAY TO PLAY (PC Gaming is expensive) or settle for a PS4 which then you will never have to ask this question again. As said NO Integrated video cards are NOT for gaming, they are made to just 'use' the PC. You want to GAME you need to BUY a GPU (www.pcpartpicker.com).
http://www.ign.com/wikis/xbox-one/PS4_vs._Xbox_One_Native_Resolutions_and_Framerates
anything above a hd7770 or gtx650 will play anything you like.
